  1. Ok, so I take a movie (Scary Movie) and rip it using DVD Decryptor. Then I load the IFO into InstantCopy. InstantCopy says that if I remove the foreign audio and subtitles then I can keep the compression level at 100%.
    So here is the big question...
    If InstantCopy says nothing has to be compressed, why in the hell does it have to go through the whole damn encoding process?? Isn't it smart enough to know that all that is needed is to remove the info and then burn it to the CD??
    And they want us to buy this program??
  2. It's not retarded but it's darn slow.
  3. Was your "scary movie" layer 1 or layer 2. (If you were loading an IFO file and not a VTS file into Instant Copy it sounds like it was Layer 1.) If it was layer 1, you didn't need Instant Copy. IC's real value is for layer 2 or DVD9 to DVD5 back ups.
