I'm trying to convert bmwfilms mov files to mpeg2 using Tmpge Plus 2.5, but program crashes after 3 seconds into conversion. I tried constant bit rates, variable bit rates, film video option, vga 1:1, 16:9. QTreader.vfq set to high priority. Stream type ES and System, all unsuccessful. Is there another program I can try?
ok, I found out the Bmwfilms.com mov files are 780x536 and aren't working with any program I've tried CCE, Tmpge and mov2avi. These movies are cool and I'm would love to author them to dvd.
have you set the VFAPI plugin to convert the MOV files in tempgenc
have you read this guide?
https://www.videohelp.com/forum/userguides/124856.php
and read the user comments also.
MOV to mpeg conversion in TMPGEnc4XP
By jay_lubb in forum Newbie / General discussionsReplies: 2Last Post: 10th Jun 2010, 02:16 -
Problem converting quicktime .mov files to mpeg-1
By jtk in forum ffmpegX general discussionReplies: 8Last Post: 2nd Sep 2008, 18:42 -
.mov to Mpeg 4 conversion issue
By Peplogic in forum Portable VideoReplies: 5Last Post: 18th Jun 2008, 18:56 -
problem converting one little file to mpeg MOV (any ideas why)
By bdaul in forum ffmpegX general discussionReplies: 5Last Post: 1st Jan 2008, 08:32 -
MOV or DV to MPEG-2
By mused13 in forum MacReplies: 5Last Post: 12th Oct 2007, 16:41
