I have a APEX AD-1100W and for some reason i get a Disc Error evertyime i try to play a dvd-r movie using Lead Data and Princo brands.
I used Nero Express EOM 5.5.10.3 to burn and even have that high compatibility checked off in the properties for the dvd-rw drive!
Could Thie Be a problem Because of authoring software?
The same dvd-r media play in my SONY 5 disc DVD changer and my ps2 also my comp using powerdvd!!
I used recordnow max and the apex reads it just fine!!
So is it just that the nero express version EOM 5.5.10.3 had this problem with compatibility?
Does the ner version of nero express EOM 5.5.10.20 solve the problem?
This only happens with dvd video!!! -
DVDit! PE works fine too. But it may still be the disc. Try to fast-forward.
Some version of Nero have had a problem. Update to the latest version. Also, be sure you burn DVD/ROM/UDF, no multisession and UDF version 1.02. That works on my Apex 1100W.
all i needed to do was upgrade to the newest version of nero!!!
With the up to dat version of nero the discs read fine on all apex's now!!!
So if anyone is having a similar problem then update your NERO NOW!!!!!!
PS3 Media Server won't play MPG or TS files.
By lovelylisa in forum Software PlayingReplies: 9Last Post: 27th Feb 2012, 11:59 -
Apex DVD player AD-1100W - remotes compatibility
By Matthias in forum DVD & Blu-ray PlayersReplies: 5Last Post: 2nd Dec 2008, 14:16 -
Media Player Classic won't play WMV files?
By majax79 in forum Software PlayingReplies: 8Last Post: 25th Nov 2008, 05:05 -
Media center video won't play on standalone dvd player
By larrym in forum Newbie / General discussionsReplies: 2Last Post: 7th Jun 2008, 23:04 -
Media Player classic won't play any video...
By reapur in forum Software PlayingReplies: 4Last Post: 23rd Sep 2007, 03:49
