  1. I have used the VCD creator to copying a movie VCD to a CD-R. When I play it in my Panasonic DVD player there's no sound! I've also noticed that the copied CD-R has files in the segment directory instead of the mpegav directory... what am i doing wrong?!?!
  2. Member adam's Avatar
    Sep 2000
    First off I have to say that I think Ez cd Creator is the absolute worst vcd burning program available.
    If Ez Cd Creator finds anything non-compliant about your mpg and you choose to burn anyways it will usually put the mpg into the segment dir, rendering it unplayable on many dvd players. I don't know if this is causing the audio problem as well its possible.
    When you load the mpg in Ez cd creator it should allow you to look at its compliance aspects. Sorry I havent used that program in a long time so I don't remember but the option is there. If you tell me what is non-compliant about it maybe I can tell you how to fix it. In the meantime I would strongly suggest using any other program to burn vcds. More than likely this alone will solve all your problems.
  3. use nero or wintogo as these will burn a compliant vcd for U... U have to uninstal easycd creator or download a patch from the nero site. U can get a demo & a crack of nero from http://www.cdrsoft.cc
    cya L8r
