  1. sony dru500ax firmware 2.0c
    trying to upgrade to 2.0e
    re problems on here today
    how do i disable dma or do i need to before i do a firmware upgrade
    this is my settings
    primary ide channel
    device 0
    device type=auto detection (greyed out)
    transfer mode=dma if availible
    current transfer mode=pio mode
    device1
    current transfer mode=not applicable
    secondry ide channel
    device 0
    device type=auto (grey out)
    corrent transfer mode=ultra dma mode 2
    device 1
    device type=auto
    my drives are as follows primary is my hdd only secondry is liteon master and sony slave
  2. cmon some of you guys must have done a firmware update
    Apr 2003
    Classified
    When I got my sony and it told me to disable the dma mode I just switched it to PIO mode and did the upgrade and it all went smoothly.
  4. red...
    In DEVICE MANAGER select your DVD-Drive and under the "General" tab note whether it is 1 or 0
    Go back to the IDE controllers in DEVICE MANAGER (the portion you pasted above) And pay attention only to Secondary IDE Channel (providing that it is hooked up to the secondary). Note the 1 or 0 you found listed on the "General" tab for your drive.
    Under Secondary IDE Channel change the "transfer mode" to "PIO mode" for whichever is relevant (looks to me like you found the DVD drive to be a 1)
    Run the firmware update. After the new firmware has loaded, change "transfer mode" back to "dma if available"
    Then reboot the pc to finish the firmware update.
    I don't have the Sony, but I just did this recently on my Panasonic and assume (oh sh*t..."assume") the proceedure to be the same.
    Hope this helps...
  5. thanks it worked perfect (well i dont know if the burner works but the update did anyway lol
