  1. Hi,
    Can someone please help me.Iam using dvd2one to reduce the size of my dvd backup's but when it is finished there is always parts of the video ts folder missing ( the last vob files ) even though i have ripped the original as a full disk and the files are there in that folder.
    What am i doing wrong?
  2. What operating system are you running aslo is your hard drive formated fat32 or NTSF. There are file limitations in some operating systems and formats.
  3. i am currently running windows 98se on a fat32 system
  4. I think that's the problem. I had to upgrade to winXP and NTFS when I first tried capturing VHS movies and ran into the file limitations myself.
    Redding, California
    clipper1971
    I use DVD2one with WinME (FAT32) with no problem. Check to see if you have a VIDEO_TS.IFO file when DVD2one is finished. If not then there was an error during transcoding. Does it happen on just one DVD? Are you using SmartRipper?
    Chas
