Hello,
I'm trying to make my .VOB(130min) file into 3 cd's with ffmpeg, my outpout .IMG files are however not any bigger then 390MB while my bitrate is at 2500. So why should i need 3 cd's instead of two, the output mpeg file is 1.2 gig this should fit on 2 cd's ??
I don't mind using 3 or even 4 cd's but only when the full 700mb available is fully used and not half of it.
Is it possible to get a higher bitrate of let's say 3500 kbit/s, should i use XSVCD settings
I realy don't know anymore so if anyone can tell me how i can get the best quality SVCD (regardless of how many cd's i must use) from my .vob file with FFMPEG
Higher settings, yes.
question is....... can your player handle the higher settings. Anything above 2500 is non standard svcd (XSVCD) as you noted
so find out how high your player can go, then do that if you dont care about how many disks. Personal experience has shown me that anything above 3 800.5 meg .bin files is just not noticable difference in actual video quality. and thats on my flatscreen 16:9 tv.
So check your dvd specs with the dvd list at the dvdrhelp.com home page and see what you can go up to.
My question for you is, how did you rip your DVD? What are you using to mux them together? Is it PAL or NTSC? Any sync problems??
I used ffmpegx for my SVCD creatoin and got horrible sync results so im just wondeirng what you do?
installation problem FFMPEG MAC Lion
By exclimber in forum ffmpegX general discussionReplies: 8Last Post: 20th Dec 2011, 12:07 -
Ripping a Region 2 DVD on a Mac Book Pro with Mac The Ripper
By Jess021 in forum MacReplies: 7Last Post: 17th Nov 2011, 06:04 -
Unable to install ffmpeg in Mac G5 MacOS Leopard
By oicram in forum ffmpegX general discussionReplies: 4Last Post: 8th Aug 2010, 10:17 -
DownloadHelper / FFMpeg won't convert on Mac G4
By Soulfilet in forum Video ConversionReplies: 0Last Post: 23rd Jun 2010, 22:22 -
FFmpeg autobuilds for Mac OS X
By Chris K in forum MacReplies: 0Last Post: 21st Jun 2010, 13:45
