  1. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Description:
    This is a guide to how to create a vcd using the program Forty-Two for the Mac.
    The newest version on this guide can be found at http://homepage.mac.com/tgpo
    Required Tools:
    1. Forty-Two
    2. Burning Software: Roxio Toast or MissingMediaBurner
    Step 1: Drag-and-Drop
    1. Insert your DVD
    2. Drag and drop the disk from your desltop into the DVD Window of Forty-Two as shown here
    Step 2: Settings
    1. Set the file format to vcd as shown here
    Step 3: Options
    1. Click the button in the top left, shown here
    2. Here you can sample different language tracks, or choose to rip a certain track or chapters
    Step 4: Sit Back
    1. When you are happy with the setting hit the start button
    2. Forty-Two will now do its thing, and this could take a while
    3. During this process FOrty-Two will spit out a 1 min sample video in your home folder, /Users/YourName
    Step 5: Burning
    1. For Toast simply drag and drop the produced files to the Toast Window and burn.
    2. For MissingMediaBurner, simply use the VCD Option and file the .cue file Forty-Two just produced.
    Version History:
    Sat April 12 2003 Version 1.0
    Initial Guide Released
  2. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Maybe a SVCD guide is in order.
