If there is some bad frames (sqaure appears for a few second) is there anyway I can fix the file some that the video can be played smoothly
thank.
You can try running it through VCDGear. It has a 'Fix MPEG Errors' option when using the 'Mpeg to Mpeg' tool, that will sometimes correct bad frames. You can find it in the TOOLS section.
Impossible to see the future is. The Dark Side clouds everything... -
you can also try this: https://www.videohelp.com/forum/userguides/142555.php
:P -
vcd gear doesn't seems to correct bad frames is said it fixed errors but when I play the file nothing was changed. anyone know what other program that is good for fixing bad frames for mepg files
thanks -
I don't think there is a way to FIX the frames that are corrupted. If there is, I haven't heard of a method. I'd probably delete the frames if it's that distracting.
Premiere CS3 exporting bad frames
By spicediver10191 in forum EditingReplies: 4Last Post: 17th Apr 2012, 18:39 -
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 09:15 -
correcting bad subtitle timing?
By chocobo in forum SubtitleReplies: 2Last Post: 26th Jul 2010, 07:33 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 16:00 -
Cutting bad frames with VirtualDubMod
By lazaruz in forum EditingReplies: 2Last Post: 18th Sep 2007, 04:39
