My TV Wonder VE card was working happily until sometime in February, when mysterious problems started popping up. The image attached to this post provides an example of this problem.
See the black bar at the very top of the image? The pattern of the grey bands inside initially led me to believe that this was noise or static that my card had trouble dealing with.
But that explanation didn't fit with the other symptoms: the fact that this 'noise' was channel- and even show-specific ruled out a static problem. Also, sometimes there is no top bar of 'noise', but rather a 3-4 pixel wide vertical black bar on the left side of the image. In some shows, the top line of 'noise' causes the video image to lose some of its information - this is most noticible as a regular 1-pixel 'jump' or semi-fade of drawn horizontal lines in animation. This looks bad even when both fields are captured (NTSC 29.97 format), but at 320x240, this vertical shifting completely ruins the video.
I read a reference somewhere that ATI's cards had trouble with handling TV signals, that sometimes the card rendered encoding sent along with the signal into the video image. I don't know if this is a failure of the hardware or of the card's drivers, but I have no idea how to fix it. It's not caused by anything cable-related, as hooking up a standard TV/FM antenna resulted in the same problem. Nor is it a problem related solely to the RF jack of the card - the composite-in has the same errors.
Has anyone else experienced this problem? And if so, does anybody know how to remedy it? (Leave it to this crappy 4-year-old machine to experience all the freaky, undocumented errors...)
"The difference between genius and stupidity is that genius has limits." - Albert Einstein
The Wonder VE was my first capturecard and I would try installing the card in another PCI slot and/or reinstalling MMC7.1,if that doesn't help I'm afraid the card is shot and hopefully still under warranty.
P.S.You might try pulling out your radiocard(due to RF interferance)
Capture problems using ATI TV Wonder HD 750
By SKot in forum Capturing and VCRReplies: 9Last Post: 3rd Jan 2012, 15:34 -
ati 8500dv resource problems
By jwdove in forum Capturing and VCRReplies: 1Last Post: 27th Sep 2009, 12:48 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 05:11 -
Cable signal problems
By timbo-wilderbeest in forum Capturing and VCRReplies: 1Last Post: 11th Feb 2008, 03:15 -
Problems with Pal-60 capture using ATI AIW 2006 PCI express Radion X1300
By DB83 in forum Capturing and VCRReplies: 2Last Post: 6th Aug 2007, 16:49
