  1. Hey all, i need HELP!!!! i got a few dvd's and i used DVDx v2.2 and Super DVD Ripper and did the all in one step and there were a few .mpeg's. When i went to burn them with nero it burnt fine at 8x Speed. When i put it in my DVD Player it runs ok but when i fast forward then press play it goes out of sync. Im sure alot of other people have had this problem but i've wasted over 10 cd's with this sync thing. I also used the Super DVD Ripper burn function and still it didnt play normally. Does anyone know why this is like this??? am i doing something wrong??? is there specific options to use when i use DVDx or Super DVD Ripper??? PLEASE HELP!!!
    from Lance.
    Operating System: Windows XP Pro
    CPU: P4 2.53GHz
    HDD: 80GB 7200RPM
    RAM: 1024 DDR PC-2700
    Video Card: ATi Radeon 9800 Pro (3D Prophet) 128MB DDR TV-Out
    Motherboard: Asus P4S8X-X
    DVD-ROM: Pioneer 16X Tray
    CD-RW: Lite-on 52X
    DVD-RW: Lite-on 4X
  2. COME ON PEOPLE!!! SUM1 GOTTA KNOW THE ANSWER TO THIS!!!
    CPU: P4 2.53GHz
    HDD: 80GB 7200RPM
    CD-RW: Lite-on 52X
    DVD-RW: Lite-on 4X
  3. Try using Eazy VCD from the tools menu, that is what I use if I want a quick and easy conversion.....works all the time.
