Heya,
I'm back!... Just doing a little experimentation... So I used OSEx to rip a DVD into an m2v and ac3 file. However, when I try to import the files into DVDSP I get this: PM error: Bad File Format. The ac3 imports just fine. So I've heard sometimes you have to import from the finder menu. I did that and got the same results. What could be wrong with the m2v file? I hear there is a way to trick DVDSP into accepting the file. What is the best way to take care of my problem?
Thanx,
Mullet
First, go back to OSEX, look at your title, and make sure there isn't a final chapter that is only about 15 seconds or so. If there is, try ripping the title without that last chapter (it's a script or something that botches up the way DVDSP looks at the video file).
If that's not the case, then run the file through PullDownX, disabling all the options including disable pulldown insertion -- and set the "DropFrame field for NTSC" option to true. See if that helps.
DVD plays, won't rip (now rips with CDRoller, won't import to TMPGEnc)
By koberulz in forum DVD RippingReplies: 14Last Post: 4th Dec 2011, 10:42 -
MPEG won't import after converting using VOB2MPG
By olweiser in forum Video ConversionReplies: 3Last Post: 20th Aug 2010, 13:44 -
DVD Studio Pro will not import m2v files!
By CLE in forum MacReplies: 5Last Post: 20th Jan 2008, 18:14 -
Home vid Vob files won't import
By JackT in forum DVD RippingReplies: 5Last Post: 8th Jan 2008, 01:29 -
Premiere 6.5 won't import DV files
By Megahurts in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Jun 2007, 22:52
