Anyone know of a easy and simple program to convert VOB files to SVCD and or vcd........??? I have used SUPER DVD RIPPER but I am unable to get it to work on my computer. Presently I am using DVD2 and converting to avi, then to wav then using tmpgenc to make a svcd. Obviuosly has to be an easier and faster way. The Super DVD ripper was great but it won't activate on my computer, will start but unable to get access to use it...??
thnx for any help
Have you tried Eazy VCD ?, this allows you to open up your ripped vobs and then convert them to vcd.
or...
you could use it to rip the files aswell. -
Look in the GUIDES section. There are countless ways. The most automatic way I know is DVD2SVCD, which has it's own drawbacks. If your looking for a 1 click (or close to it) solution, try that. Just be aware that it does take some configuring to get it working properly, and you will need at least a minor working knowledge of what your doing.
I'd suggest you start in the guides section under DVD TO and go from there...Impossible to see the future is. The Dark Side clouds everything... -
Thnx for the info..... I tried the DVDx and it seems to do what I want with decent quality..
thnx for the help -
It is true DVDx is easy, but in truth the quality is the worst. Only good VCD.
I started here with the SVCDs and have learned alot since.
I rarely do a SVCD but if I do I use Mediator with bbmpeg. 5 hours but great quality on playback.
I am a bit different in that I want free.
VOB files too fast/out of sync in Vegas Pro 10.
By rcavanah in forum Video ConversionReplies: 7Last Post: 10th Sep 2011, 21:14 -
Easy/Fast MPG to DVD Options?
By beckmen in forum Video ConversionReplies: 5Last Post: 25th Feb 2010, 18:41 -
Fast .ts > .mkv conversion
By NewbieCanuck in forum Video ConversionReplies: 4Last Post: 3rd Feb 2009, 12:05 -
How to convert DVDs to AVI (fast, easy, 90% quality retained)
By guns1inger in forum Newbie / General discussionsReplies: 1Last Post: 12th Jan 2008, 09:56
