Hi All
I have converted a film on to a CDRW disk, and on my own DVD player I can watch the film no problem.
However, when it comes to playing in a friends DVD player the disk is automatically ejected and does not play.
Is this a problem with the player not being setup for Multi Region?
Many thanks
Cyberdood
If there is it will be in the hacks section
It might just be the type of disc, try it on a standard cd-r
My sony dvd player will not play cdrw's but will play normal cdr's.
Good luck :P -
thanks for the reply.
yes we were using a cdrw, we will try burning onto a standard cdr
just for your information the type of dvd player is a samsung 709/xeu
best regards cyberdood -
It's most likely that the DVD player doesn't read CD-RWs. The standard for DVD players is to support VCD, so a CD-R should be playable.Originally Posted by SLICK RICKThe more I learn, the more I come to realize how little it is I know.
Hi Chaps
thanks for yuor help today.
I have just got back from purchasing some new CDR's
We will gibe that a whirl tommrow.
regards
Cyberdood -
Looks like that player won't play CDR or CDRW as may be seen here.
https://www.videohelp.com/dvdplayers.php?DVDname=samsung+709+&Search=Search&best=Latest+Updated
And here is a user comment.
"This player is one of the old ones. It does not play most VCD's. I have tried burning with, Nero, Ulead, and Dazzle. Non of these VCD's play. Also the loading time is extrememly slow. Its time to upgrade."
DVD Player problem playing .avi
By dexter30 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 17th Sep 2009, 01:18 -
xvid avi problem when playing on eternal dvd player
By myname77 in forum Newbie / General discussionsReplies: 2Last Post: 16th Sep 2008, 11:26 -
problem playing Philoco dvd player moga juniour 400
By akhtar123a in forum Newbie / General discussionsReplies: 1Last Post: 6th Aug 2008, 10:17 -
Playing DVD burned slide show on DVD player problem
By zenfoos in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2007, 22:37 -
Problem with playing DVD in standalone player
By tngolfn in forum Newbie / General discussionsReplies: 2Last Post: 14th May 2007, 18:41
