  1. i used forty-two and it created a 1.35mb file, what app can i use to split the file so i can fit to 2 X CD?
  2. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    word of advice
    dont make new post for a question you asked in a post that was also by you. people read the posts all the time, so justbecause you think 3 or 4 replies later no one will answer a question is not true. This helps to keep the post free of clutter and repeats.
    OK
    try the avi splitter
    http://www.macupdate.com/info.php/id/10958
    it should split the file for you.
    likewise, you can usually find a program for just what you want at either macupdates.com or versiontracker.com.
    i just typed in DIVX SPLIT and this program came up.
    that simple.
    best of luck
    -galactica
  3. thank you for your advice, i did search and find split me from VT, but it wont work for some reason....
  4. Member galactica's Avatar
    Jan 2003
    why not try the link i provided??
  5. Never mind... too fast on the key board
    Dec 2002
    MN USA
    Try FFmpegX 6 and up.
    It's what I use for spliting .avi's.
    Go to the tools tab, deselect everything on the right except avi split.
    Fill in the blanks and your done.
    Also make sure the file name doesn't have any weird characters in it.
    ffmpegX doesn't seem to like them.
    Hope this helps.
  7. Thanks for everyones help on this matter. Galactica, I had searched versiontracker before my original post but found *split me* only working on some avi files. I will try FFmpegX and see how it goes...
    again thanks to all who posted...
  8. Member galactica's Avatar
    Jan 2003
    if ffmpegx doesnt work for you, and you have Virtual PC, there are MILLIONS of programs for pc that will work, and you might have better luck with one of them
    ffmpegx should work, dont know why i didnt think of that earlier
