Here is my problem,
I try to frameserve with virtualdub and it locks up my TMPegenc big time. Then when I try to open tmpeg afterwards, it won't open. It runs in the background because it is in my system tray. So I have to uninstall and reinstall tmpeg to get it to work.
Is there arnother way to just permanently add subtiltes in a movie? I already have the divx file and I have the subtitle file. Can I just burn the subs directly into the divx file somehow?
Cade
Install latest ffdshow from www.doom9.org .
Run the ffdshow configuration(start menu->ffdshow->configuratio). Enable the subtitles(click on the subtitle box).
Name the subtitles to the same name as the video file but with a .sub or .srt extension instead of avi.
Open the video in tmpgenc and the subs should be there(use the file->preview to check so you see the subs). -
I appreciate this...I will give it a whirl and try it!
I'll let you know how it goes.
Thanks Again,
Cade -
I was very excited to see that it worked!
However, I was only able to get it to work for one movie.
The other movies I try give me nothing but sound and no picture or subs. I raised the priorities in Tmpgenc but it has had no effect.
Vobsub's little green arrow comes up when I load the file too. When I play the avi now, the subs automatically play.
I Unisntalled VOBsub and I got the picture back but no subs.
Any other suggestions?
Cade
Add subtitles to existing dvd movie
By woodtogo in forum SubtitleReplies: 13Last Post: 20th Apr 2011, 17:55 -
how to add subtitles in mp4 movie
By d2idan in forum Video ConversionReplies: 33Last Post: 6th Feb 2011, 23:56 -
Add subtitles to an hd movie
By zoloabc in forum EditingReplies: 1Last Post: 2nd Feb 2010, 02:06 -
Add subtitles to a series DVD, not just a movie (problems with Muxman)
By gimeis in forum Newbie / General discussionsReplies: 24Last Post: 9th Sep 2008, 01:39 -
How can I add my subtitles in Cyrillic to a movie?
By Misterygirl in forum SubtitleReplies: 19Last Post: 17th Jul 2008, 13:51
