Maybe someone knows this answer because I sure don't. I just purchased the WinTV PVR 250 card (software version 1.6a) which comes with Movie Factory SE. Also I have installed Ulead 6.0 Pro. I can video capture to the PVR 250 card but when I open MF or Ulead I can't capture there. On the Movie Factory I get a message saying "No input signal or signal is unclear. On the Ulead program is just won't come in. Now on the Hauppauge under WinTV 250/350 questions it says the MF SE is just for editing and not capturing. Does that make sense to include a problem if you can't use Movie Factory. I can't figure out why...Any help would surely be appreciated...Thanks YB![]()
I have been using the PVR 250 card for the past 8 months. I have contacted many of the DVD editing programs support people (Ulead, Pinnacle, Intervideo to name a few. All with the same answer. The PVR 250 card is not compatable for capturing direct into editing programs.
I will capture TV tuner and VCR with the WinTV 2000 program and then import the file to a Edit program with very good results. I use Ulead DVD Movie Factory, Video Studio 7 and recently NeoDVDplus. This is the only way. Never got an answer from Happauage about this program. I like the WinTV 2000 for capture because if your into DVD it gives you lots of capture options.
Happauage WinTv PVR 250, software concerns and advice.
By MidnightMike in forum Capturing and VCRReplies: 6Last Post: 25th Aug 2011, 11:37 -
Hauppauge WinTV-PVR 250
By thatsgame1 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jun 2011, 07:54 -
Hauppauge WinTV PVR 250
By kenmo in forum ComputerReplies: 10Last Post: 28th Apr 2009, 14:21 -
What software for capturing Hi-8 with Hauppauge WinTV 250 PVR USB2?
By boscabru in forum Capturing and VCRReplies: 10Last Post: 5th Mar 2008, 03:19 -
Unable to capture from camcorder with WinTV-PVR 250 card and and WinTV2000
By forestial in forum Capturing and VCRReplies: 1Last Post: 29th Dec 2007, 20:00
