Hi. I'd like to know if there's a way to rip episodes off a DVD?
A little explanation. (I followed the GKnot DVD=>DivX at doom http://www.doom9.org Guides --> Divx / Xvid --> DivX5)
I've gotten Evangelion (a Japanese Anime) and I was ripping the DVD's with GKnot / Robot4Rip and everything was fine because the .VOB was one large file with all episodes on it (each episode is ~23minutes long and the .VOB was ~152mins long) (4 episodes). So I could rip the entire thing and then split it up later.
After a few DVD's they decided that they'd seperate each episode into it's own file and only put 3 episodes per disc, so I thought that I'd just rip each one separately:
VTS_04_0/PGC 1 [00:23:34]
VTS_05_0/PGC 1 [00:23:34]
VTS_06_0/PGC 1 [00:23:34]
That didn't work and the vobs ended up being ~57mins (for VTS 04), ~35min (for VTS 05) and ~23mins (for VTS 06) while the ripped Audio wasn't the right audio for the episode.
A screenshot of what I'm talking about is here http://rufus.envy.nu/r4r.htm
Any info is helpful thanks. I don't mind if there's a way to rip the 3 episodes to one large file, or ripping them separately if need be. As long as I can rip them and have Audio/Video sync.
Ultimately I want to burn to VCDs. But as long as I can get the DVD to an AVI I can work from there.
I think DVDDecrypter will let you have the result you're looking for with ripping seperate chapters or episode IMO. If that doesn't work then I guess its off to DVD2SVCD.
dvd episode ripping? can't find hole file.
By David9799 in forum Video ConversionReplies: 6Last Post: 23rd Aug 2010, 08:20 -
Ripping a multi-episode DVD
By scoopyx in forum Newbie / General discussionsReplies: 5Last Post: 21st Dec 2009, 22:55 -
I have a problem with ripping multi-episode DVD
By jemping in forum DVD RippingReplies: 7Last Post: 27th Oct 2009, 11:42 -
Multi Episode dvd's with single title, Ripping troubles
By Malicious in forum DVD RippingReplies: 11Last Post: 5th Aug 2008, 09:32 -
Ripping one TV Show DVD Episode into ONE File
By ronhammond71 in forum DVD RippingReplies: 11Last Post: 5th Jun 2007, 10:42
