Hi,
I am trying to convert mov files to VCD using TMPGEnc. I have done this countless times before, but then my computer crashed (not related to TMPGEnc BTW) and I lost all my software. I have just downloaded the latest version and the QTReader. It seems to work fine but the final mpeg has no sound.
A bit of research, and I have found out that some mov files are protected against re-encoding, and that apparently there is no way round this. I have tried using radtools, but it said that it couldn't open the audio stream. I therefore suspect that it is a protection issue. However, when I tried encoding an older mov file, it did the same thing. The odd thing is, that I successfully converted this file with sound before my computer went down. So I was therefore wondering if anyone could shed any light on this situation, and hopefully offer a solution.
Results 1 to 1 of 1
help -No sound when converting .mov files
By bloke666 in forum ffmpegX general discussionReplies: 0Last Post: 11th Dec 2011, 11:48 -
Converting or Joining MOV files
By theWallflower in forum Video ConversionReplies: 3Last Post: 8th Apr 2010, 07:00 -
Batch Converting MOV Files
By thomasj in forum LinuxReplies: 3Last Post: 25th Dec 2009, 14:50 -
Converting files to Mov For (CyberPix DV-20 CM-ME-DV-20HDRD)
By Zerodude in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2008, 08:48 -
converting .mov files to something I can use
By weazel_k in forum Authoring (DVD)Replies: 2Last Post: 1st Sep 2007, 16:46
