Hi.
Is it possible to record/capture 2 television shows from different channels simultaneously into my hard disk? I currently have a PixelView PlayTV HD tuner/capture card and couldn't find any info on how to record 2 TV shows at the same time, without the aid of a VCR.
Thanks.
To get multiple channels, you need multiple tuners. I don't know of any cards that have more than one.
The tuner in your capture card is a hardware device that is only capable of tuning in one channel at a time. Theoretically, you may be able to capture two channels at one time using two capture cards, but I'm not sure what software you would be able to use. It will have to allow multiple instances running at the same time with different hardware configurations. More likely you'll have to use software from two different companies. You'll also need a fairly fast computer and more than likely seperate hard drives to keep up.
Stream & Capture Simultaneously?
By GuidingLight in forum Video Streaming DownloadingReplies: 1Last Post: 19th Jul 2011, 16:15 -
Capture and Record US Cable Channels in full HD?
By onesikgypo in forum DVB / IPTVReplies: 14Last Post: 2nd Jun 2010, 22:42 -
capture crypted channels
By Solona in forum DVB / IPTVReplies: 3Last Post: 25th Feb 2009, 16:15 -
audio channels problems, during capture
By popo128 in forum Capturing and VCRReplies: 0Last Post: 5th Aug 2008, 04:25 -
Can I capture video on DV tapes and computer hard disk simultaneously ?
By AAC in forum Capturing and VCRReplies: 7Last Post: 12th Mar 2008, 14:05
