Results 1 to 26 of 26
  1. Hi Everyone ,
    I'm very new to the whole world of backing up DVD's but it's good to see such an involved forum.
    I'm sure someone has asked this before but I've tried a search but with no real result. I was just wondering if anyone knows how to burn a DVD with the Main Menu but WITHOUT the extras. I can do movie-only backups using DVD Decrypter but I'm a bit anal and I want to have something that "sort of" mimics the original when I put it in my DVD player but retain as much quality as possible.
    I'm still trying to learn IFOEdit which seems like it can do it.
    Does anyone have any tips/advice? I'd really appreciate it.
    Thanks!
    boodoo
  2. If you want to read, learn or ask, go to Doom9's IfoEdit forum.
  3. BOODO...........you are in the same boat as me...
    I too want to make backup dvd's with the menu title and just the movie only......i have found a way of barring out the extra feature buttons/tabs on the menu's but when u strip away the extra vob files the whole dick becomes abit unstable and no ripper prog will touch it to resize it for a single disk................
    PLEASE somebody explain simply how to do it as ifoedit seems complicated to me aswell...............
    MATT_THE_MOUSE®™
  4. I can do that with DVDshrink by just setting the extras to be still pictures in the custom compression screen. That way the size of the extras goes to near zero freeing up space for the main movie.
  5. Originally Posted by Bob W
    you tryed ? I made a test but didn't burn it to test on standalone DVD player. if it work, it's a good way to have only few extra if you want
  6. Originally Posted by vric
    Yeah it worked just fine.
  7. Originally Posted by Bob W
    great ! I order my DVD burner this week
  8. Sounds ideal! I'm going to give it a shot right now
  9. Another good way to do it is by Pinnacle's Instant Copy. You can get it for $30 after rebate. You can delete any extras, subs, and audios that you don't want. All the menus will be left intact. If the remaining materials fit on one disk, it will burn or create files to burn without re-encoding. If the material won't fit, it will re-encode to fit.
  10. Originally Posted by falberni
    I read here that if you remove some extra with IC7, it will corupt the IFO file and will be unplayable on standalone DVD...
  11. Member wulf109's Avatar
    Jul 2002
    I did this with ALIENS and DVD95COPY. Identify and then delete the vob files for the extras. You need to keep the ifo files for the extras. Works perfectly on my DVD players,menus run and you can select the movie.
    Tried this with DVD2ONE,but it will not accept the input without the vob files.
  12. Originally Posted by falberni
    Is their a good guide on how to do this I havent used IC that much and want see how its done, didnt find any in this forum using search. How long does it take to convert it with IC.
    I tried doing adding the menu's on DVD shrink the menu's dont work though if you click on them.
  13. Yes, there's a very good guide. The link was posted in one of the threads here. I copied the guide as a mht file on my HD. I don't remember the link though. If you want it, pm me and I'll e-mail it to you.
    Out of the box, you won't be able to select the tiltes you want copied. The software will shrink the entire content on one disk. However, there are a couple of registry hacks that would make it very easily possible to select only the tiltes you want. For example, you may not want the extra scenes, the leaders, the trailers, etc. If there are two versions of the main tilte, such as wide screen or full screen, you can select which one you want. You can find the links to the registry hacks from the guide I just mentioned. I'll see if I can find the link and I'll post it if I do.
    IC will re-encode the tiltes so they fit on one disk. Therefore, it is kind of slow. I think the quality is one of the best.
  14. I just found one http://www.mrbass.org/instantcopy/ Let me see how this works.
  15. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    my guide may help you a little
    link in sig
  16. mysterio,
    Yes, you found the guide that I was referring to. The other guid that was posted MacemX is also good and some more links. You're on your way.
  17. Thanks guys that other guides looks good too.
  18. Member
    Apr 2003
    Poland
    hullo I've got a question about shrink.... we can cut the extras and etc to for a comression or example still movie (which means for me 1 SQUARE per second) but the extras will play with this speed on the standalone players we solve the problem but not exactly... question is how in a simple way (not a ifoedit) do that those extras bonus etc. wil be deleted without changing structure of menu and navigation...option "still movie" creates bad feeling in user... you have to watch slow motion extras I'm still tryin' to find a way to cut them out but I realy lost of possibilities try to understand a freshman and help please One and only problem is to loop the navi bars to that same screen after the extras are gone....
    Sep 2001
    N/A
    if I were you id use dvd shrink to rip and turn the extras you didn't want into still frame thingys, then I would reencode the main movie in CCE.
    After all that I would use menu edit to remove the buttons to the extras I didn't want.
    Baker
    My vcd & cvdGuide
    Dec 2002
    The Great Northwest
    IC7 with Hidden Settings and reg hacks will give best results I have found for a near one click solution IMHO.
    justmy2cents
    Dd
    http://www.dvd9to5.com/
    http://www.dvd9to5.com/Instant_Copy.htm
    http://www.dvd9to5.com/Instant_Copy_UD.htm
    http://www.dvd9to5.com/Just_Software.htm
    http://forum.doom9.org/forumdisplay.php?s=&forumid=65
    htttp://www.pinnaclesys.com/ProductPage.asp?
    (;-{> Dd
    Strength and Honor
    www.dvd9to5.com
    www.dvd9to5.com/forum/
    "For every moment of truth there's confusion in life"
    Black Sabbath/Ronnie James Dio
  21. Originally Posted by jungli
    Menuedit does exactly what you are looking for.
  22. Originally Posted by baker
    Baker
    Have you tried it and did it work ?? I think I know how to use Ifoedit to strip out the unwanted screens for the extras from the VOB files but the problem is when I click on the menu link for the extra the player hangs because it gets confused somehow. I;m not sure what else i need to do
  23. Member
    Dec 2002
    Texas USA
    So many hard options listed. I'd just use DVDshrink. Works for me. I kill off junk I don't want and THEN make it fit to 1 DVD-R.
    I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
  24. I found the solution to my problem, kinda, I used menuedit prog to disbale the menu pointer
  25. I haven't tried MenuEdit yet but I've JUST tried using DVDShrink but I hit a weird problem when I burnt it.
    I reduced the size of all of the extras and left the movie and the main navigation menu intact (including the lead in and lead out to the menu) However, when I burn it, the navigation and directory structuring has gone so now when I put it in my DVD player, it goes into the main menu but when I try and select the "Play Movie" option, the cursor dissapears and it continues to play the length of the menu screen and then it plays through each of the static screens from the extras until it gets to the movie (which is Title 13 out of 17)
    Anyone have an idea why this might happen? Would it work if I just use DVD Shrink to encode the menu lead-in, the menu itself, the lead-out and the movie itself?
    Thanks!
    Boodo
  26. I was reading above about how to use DVD Shrink to turn all the extras
    you don't need to still images to save space. What happens when you try
    to access an extra (that is now a still image) from the main menu? Does it
    just show you a blank screen then return you back to the menu? If not,
    do I need Menu Edit to disable the button associated with that menu.
    Also, let's say the main movie is from VTS_01_1.VOB to VTS_01_6.VOB
    and this is re-encoded through (say DVD2DVD-R) so that it now only
    takes up 4 VOBs, I assume that DVD Shrink now updates the IFO file for
    it to reflect the fact that the main movie now only takes up 4 VOBs?
    I'm new to this so any help would be nice
