To convert a dvd I use smartripper to rip the vobs and then I use vob2avi to rip the sound and use the d2v file and sound file from that and convert to what I want with TMPGEnc.
I am wondring how can I creat a subtitle d2v file to convert in TMPGEnc. I would rather use a d2v file cuz I know that is a good quality input file, but is there is an easier or better way to attach the subtitles to a file to be converted in TMPGEnc that is good to. Thanks for any help.
Did you look to the left under "DVD Rips" there are guides for making x(S/C)VCDs and DVDs with subtitles.
Most people rip the subs from the DVD, then load the d2v video and subtitles in Virtual dub, and frameserve from VDub to TMPGenc:
https://www.videohelp.com/sefy/
this guide as WAY MORE info then you need, but it's all good stuff
Take a look at some of the other ones in the DVD Rip section here and at doom9.org
I just found this thread by searching for help on making subbed VCDs from DVDs using TMPGEnc, after looking thru the guides, so sending us back to them isn't much help...
-= She sez there's ants in the carpet, dirty little monsters! =-
Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more!
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 09:22 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 18:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 10:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 17:28 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 18:10
