Yes, I have gone over the columns on the left alot. But I am still unsure what alot of this stuff means. I have been d/l That 70s Show for about 3 weeks now. Everything was going well up until 2 days ago. I have been using EO Video to do my conversions b/c it was a very simple program to learn. I was on this site a few days ago and decided to try TMPGEnc for the first time. It was a disaster.
My problem is I had a disk that would just not play right. I tried 4 times to convert and burn it. It was constantly choppy. I finally got a copy to play good on 1 of my 3 dvd players(the generic one) if I zoomed down to 1/2 screen size. What is a template on TMPGEnc that I can use to avoid this again? or should I just stay with EO?
I have burnt several more disks since then and haven't had any problems. I create the disks in vcd format and use Ulead to burn the disk. I hope I have given enough info so that someone can help me. Thanks in advance.
what were your settings in tmpgenc?
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Again, with me being new to it, I'm not sure. I thought I had it set to VCD template 4:3 Pal, but I was so confused. The first time I used it, I had this site up to direct me, but I had to have screwed it up somewhere. All of the conversions I did with EO were in PAL, 25fps, CBR, 352x288, 1150kb/s. I tried to set up TMPGEnc the same way but I knwo I screwed up.
AVCHD converting questions
By subock in forum Video ConversionReplies: 3Last Post: 24th Sep 2009, 19:08 -
some converting questions
By scarlac in forum DVD RippingReplies: 13Last Post: 12th Jul 2009, 08:57 -
Few questions about converting with GOTSent
By Mortifix in forum Video ConversionReplies: 0Last Post: 10th Jan 2009, 14:49 -
questions on converting RM files
By sprilite in forum Video ConversionReplies: 2Last Post: 9th Mar 2008, 23:08 -
Converting VOB to dv questions
By brewfeller in forum ffmpegX general discussionReplies: 2Last Post: 5th Oct 2007, 11:18
