Like many of you I am very frustrated at the lack of a reasonably priced reliable program that allows some creativity! Any gossip as to when any new products may hit the market?
First of all it depends on your definition of "reasonably priced reliable program that allows some creativity". Let's face it it some people think Sonic DVDit is the greatest thing since sliced bread, while others won't look at anything else unless it's Scenarist.
Adobe are touting their new DVD authoring program called "EncoreDVD". The blurb is on their web site. It will cost $549 when released in the summer. -
Sonic DVDit is fine in terms of creativity, it is just so unreliable! So many crashes!
I m sure that Adobe will as allways set the standard -
DVDlab will hit the market soon, you would be wise to wait. to see this under $100 product. See www.mediachance.com for info. I believe the author (Oscar) plans to release it soon.
DVDlab looks like exactly what I have been looking for.
Let's hopw Apple doesn't buy it in it's first week like with SpruceUp! -
If you go to www.filemirrors.com and search for DVDLab you can download what I assume to be the beta (I haven't tried it yet).
Or you can go to mmbforums and DVDlab section to find the link to the pre-release.
Most people can do great DVDs with this version while others will need the release to make their projects work.
DVD authoring programs - suggestions?
By jakewoodblues in forum Authoring (DVD)Replies: 3Last Post: 22nd Apr 2010, 13:53 -
Recommended DVD authoring programs...
By mjl1297 in forum Newbie / General discussionsReplies: 23Last Post: 18th Feb 2010, 21:14 -
DVD authoring programs and their MPEG2 encoders?
By Valnar in forum Authoring (DVD)Replies: 7Last Post: 27th Dec 2008, 09:26 -
Should I consider other programs then DVD shrink for DVD9 to 5 authoring?
By geepondy in forum Authoring (DVD)Replies: 11Last Post: 3rd Apr 2008, 17:42 -
dvd burn fails in all software authoring programs
By jfrenchu in forum Authoring (DVD)Replies: 8Last Post: 9th Feb 2008, 22:39
