Poll: which is the best video capture for dvd that costs $80 or lower
Be advised that this is a public poll: other users can see the choice(s) you selected.
Results 1 to 9 of 9
  1. ok i have apretty large vhs collection that i want to convert to vcd/dvd please cast your votes to tell me which one is better
  2. Hello,
    $80 I donīt know, but $200 I recomend Canopus ADVC100 is very very good......
  3. For $10 on sale at CompUSA the Aver card is a no brainer IMO.
  4. i cannot make this choice based on one vote
    Apr 2001
    Virginia
    I recommend the Leadtek Winfast "Deluxe" TV2000XP. There $54.99 with free shipping at newegg.com. Over 150 positive reviews also. My cousin has one, I've played around with his alot. Im pretty sure it can do exactly what your trying to do with this card.
    What's This Do?
  6. The Prolink Xcapture or TV PVR both have the new conexant chipset i personally have both and they rule!! noise free, a bit tricky to get it to work the tv pvr that is with showshifter but once you get it it rules xcapture is 39.00 the tv pvr is 69.
  7. avermedia card nice budget one mpeg 1 and two no marcovision problems, solid tv tuner, , wouldnt buy a more expensive one, depends if you are going to use it after you have transfered if you are then spalsh out.
  8. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    Well do us all afavour and Read the guides then, that's what they're there for
    Will
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
    Dec 2002
    Texas USA
    Everything under $200 is pretty much the same. Just buy what's on sale since money, rather than quality, is your determining factor.
