Hello,
My disk is formated as FAT32 but I only capture file until 4GB, after this the Premiere finish the capture and say that the limit of file was reached. I donīt know what to do!!!!!!!
Obs: The limit of capture file in premiere is disable.......and the time limit too.
Your disk should be formatted to NTFS, right? Just my opinion.
Hello. -
The maximum filesize under FAT32 is 4 Gb. You will either have to capture over several files or (if you are using WinNT/2000/XP) convert over to NTFS.
Regards.Michael Tam
w: Morsels of Evidence
MPG files are too large
By sldvd in forum Video ConversionReplies: 2Last Post: 6th Mar 2011, 06:59 -
Copying Large Files
By persephone in forum ComputerReplies: 14Last Post: 13th Dec 2010, 04:23 -
video files are to large!!!!!!!!!!
By sharmine in forum Newbie / General discussionsReplies: 3Last Post: 5th Jan 2008, 07:30 -
ImgTool Files Too Large
By opieandy in forum Authoring (DVD)Replies: 4Last Post: 27th Sep 2007, 22:08 -
Dr. DivX converts large VOB files into tiny unusable divX files
By texas1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2007, 22:44
