i have my geforce 2 for 4 months now
but 2 days i restart my pc and my geforce 2 makes wierd noises
i just reinstall my pc but no changes
what can i do about this
Video or sound noise?
If it's sound and you are sure that it's the video card is causing it then it can only be caused by the fan. Open the case (with the system off) and see if the fan is full of dust. If you have a cat or dog the hairs could get caught in the fan.
If the fan looks dirty then pull the card out and clean it.
If the card is not visibly dusty then I would guess the fan bearings are causing the problem. Take it back to your retailer for an exchange.
Some noise coming from the case can be misleading with noise bouncing off the case. Other possible noise sources include CPU fans and power supply fans or vibration when the case base is not stable or the case is not closed properly.There's not much to do but then I can't do much anyway. -
Im sure your G-Force 2 does not have a fan on the card, or else I would tell you to stop the fan with your finger while the computer is on. Try and isolate the noise to either the CPU Fan, power supply fan or case fan maybe. Other than that, that would be my troubleshooting tips. By the way why did you post this issue on this forum?
what is the worse thing that can happen if just remove the fanOriginally Posted by jdizzy40
By the way why did you post this issue on this forum?[/ didnt know anywhere else to ask -
I take it then that how video card has a fan? No you don't want to remove it. Check to make sure you have a fan on the card first. If you do and the noise is still present. Try stopping the fan with your finger while sytem is on. If the noise stops then this is the problem. You'll need to find an after market replacment or replace the card. Did you follow the other recommendations posted by others? Please let me know what you find out.
i know its the fan form the card
cause now i hear nothing any more
i removed the fan form the card -
Well the Chip on the card is going to get hot and under load will cause you problems if not eventual failure. The fan draws the heat away from the graphics chip. It needs something and soon. A G-force 2 is not an expensive card to replace, not like the ATI 9700 Pros that I run. Well good luck!
Composite Output Problem with Nvidia Geforce 4 Ti
By Computer Nerd Kev in forum ComputerReplies: 24Last Post: 20th Aug 2011, 18:16 -
Geforce 8400 GS
By zoobie in forum ComputerReplies: 1Last Post: 5th Nov 2007, 03:02 -
Geforce MX 400 - 64mb...is it the problem???
By fgtan in forum Media Center PC / MediaCentersReplies: 4Last Post: 28th Oct 2007, 21:54 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03 -
nvidia geforce 7800gs AGP V's geforce fx 5500 AGP
By stackner in forum ComputerReplies: 5Last Post: 15th Jun 2007, 14:22
