I'm a newbie at all of this, so sorry if this is very simple to fix or if it's been answered before.
When I play PAL VCDs that I've authored on my standalone DVD player, the picture is shifted about 15 pixels to the left. I know this because credits are futher to the left of the picture than the right, and items in menus that should be centered are futher to the left of the picture. This doesn't happen with DVDs though.
Thanx in advance.
Are you sure this is only happening on the left and not on all sides? All tv's, that I know of, have what is called overscanning. The outer edges of the picture on all sides are cut off and the amount of overscan is usually right around 12-16 pixels.
If the picture is definitely shifted than double check to ensure that your dvd player is set to pal playback mode.
Also make sure you encoded with the 4:3 aspect ratio. -
Yea, it's not overscanning. My TV does overscan alot, but this is different. The picture is shifted to the left, not just cut more on the left. I encode at 352x288 (correct right?).
Doesn't anyone have an answer for this? I'm sure others are having the same problem.
I asked this question a couple of weeks ago and the answer seems to be that if your DVD player is set to RGB output, the "to the side" problem will occur.
Within the DVD player settings, set the output to Video (or what other outputs you have other than RGB) and the problem should go away. It worked for me and it didn't cause any difference to the picture quality.
Hope that this helps.Cole -
Originally Posted by txpharoahCole
Blu Ray Player Vs DVD Player upscaling picture
By mukeshs in forum DVD & Blu-ray PlayersReplies: 10Last Post: 10th Dec 2010, 02:21 -
Shifting Chapter Point on DVD without reauthoring
By Instant Martian in forum DVD RippingReplies: 4Last Post: 4th Sep 2009, 10:10 -
Media Player Classic subtitles get smaller from left to right.
By Monzta in forum Software PlayingReplies: 5Last Post: 16th Dec 2008, 00:34 -
vcd playback - flickering picture on one dvd player, fine on another
By i_ming in forum Newbie / General discussionsReplies: 5Last Post: 21st Oct 2007, 07:41 -
problems running avi files on ext player( clips shifting postions)
By auto7890 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Aug 2007, 03:11
