  1. Using dvd decrypter, dvd2one and recordnow max to backup harry potter chamber dvd
    dvd decrypter and dvd2one went ok but while burning get this error
    ERROR-10 at sector 1911712-disc write error command:2a sence:03 ASC; OC ASCQ;08
    It was at 80% first time tried again and it happened at 91%
    used media i have used before with 100% sucess datawrite yellow
    tried other media 4th gen bulkpaq but same happened
  2. Try this in RecordNow Max tools/options/data disc un-check the option where it says "recognize the VIDEO_TS and AUDIO_TS folders per the DVD specifications" and see if the error goes away.
  3. I have got a copy to work but im not happy with the sucess rate one out of five (previousley had 6 out of 6 with this setup and media)
    also it always happens at the end of the disc80% to 90%
    the only thing i have done different to previous sucesses is now add the audio folder which i did not do before but have been told is best to do.
    so i will now go and try what you say bob and see if this helps the only problem now is i will have to use the same media\dvd movie to get comparisions then if one works i will be thinking this is just 2 out of 5 then i will have to try again (all my discs will be full of the same movie lol)
    one more thing what exactly does this
    do..
    thanks
  4. I don't know what it does but I have seen posts here were they say to disable it (I have it disabled). Also I have burned about 300 disc without any AUDIO_TS folder and they all play in the three different DVD players at home.
    BTW I don't use the main RecordNow Max program and just use the wizard and do a data disc but I doubt that makes any difference it's just a little faster for me.
  5. [quote]BTW I don't use the main RecordNow Max program and just use the wizard and do a data disc but I doubt that makes any difference it's just a little faster for me
    [quote]
    tried this for now but how come it only takes 15 mins when burning the other way takes a hour does it play in stand alone dvd players this way
    did not work this way also got same error
    Sense:06 ASC:29 ASCQ:00 (Command:2A)
    Sony DVD RW DRU-500A (E ATAPI (2.0c)
    PX.DLL - 1.1.0.358
    PXMAS.DLL - 1.5.0.109
    PXWAVE.DLL - 1.2.0.85
    PXWMA.DLL - 1.0.0.2
    going back to the way i was sucessful with before see top of post and try again with the option ticked you sugested
  6. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    Low tech suggestion, when was the last time you cleaned your burner? I know it's basics, but sometimes it's the easiest to overlook.
  7. the burner does not need cleaning its new but thanks for the input anyway
