Basically the subject line explains my dilemma. I captured some avi files using my Video capture card, encoded them using TMPGEnc and everything works fine (Audio is in sync for all of them). It's just when I join the 3 or 4 mpg's together that the audio goes out of sync ever so slightly close to the end.
Now I've added the individual mpgs in VCDEasy and burned them onto the same CD and the audio is in sync all the way through. I'm just curious if anyone else has had problems with this at all? I've been using TMPGenc Plus Version 2.58.44.152
I'm having the same trouble.
Does easyVCD play them as one movie? I can't find a way using this program to join mpegs? -
I've been burning them using VCDEasy version 1.1.5 and I've had no troubles that I can see. It plays it smoothly all the way thru with no breaks inbetween the mpg clips.
I draw the line at more than four mpeg's, TMPGEnc always seemed to through them out of sync for me too.
Try it with two, maybe three and see if the same happens.
I no longer use it, I just author with individual clips.
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
joining mp4 files but audio out of sync
By Liselotte in forum Newbie / General discussionsReplies: 2Last Post: 1st Aug 2011, 21:18 -
audio sync problem joining two avi files
By kthan in forum EditingReplies: 11Last Post: 2nd Apr 2011, 12:52 -
Audio Sync Problems when converting MPG to Divx
By kbehel in forum Video ConversionReplies: 1Last Post: 16th Jan 2009, 21:18 -
Audio out of sync (with over 0.5sec) when joining multiple avi files
By andy_blah in forum Video ConversionReplies: 28Last Post: 10th Aug 2008, 14:55 -
Audio Sync Problem Joining 2 AVI's Together from a 2 DVD Set
By boofer in forum EditingReplies: 6Last Post: 22nd Jul 2007, 01:29
