I know another boring audio sync problem but would appreciate some help
Can someone please tell me how I go about decompressing audio stream to uncompressed wav file and then recompressing with a constant bitrate enoder?
I'm getting the usual VBR warning causing 3318 ms of audio skew.
If you could give me info on a guide or a quick explanation would be even better
I've already converted the video using Tempgenc, however if i can just fix the audio to match I'd be able to author and burn
Thanks![]()
Results 1 to 1 of 1
VDub & AviSynth: Errors with ffmpeg and VBR audio streams
By klischee in forum Software PlayingReplies: 8Last Post: 20th Aug 2011, 19:13 -
Need help with virtualdub error involving VBR encoding
By Hark in forum EditingReplies: 16Last Post: 11th Feb 2010, 23:45 -
Virtualdub has detected an improper VBR audio encoding
By lingoguysw5 in forum AudioReplies: 17Last Post: 26th Oct 2009, 10:12 -
VBR encoding problems with TMPGEnc 4XP
By maccool111 in forum Video ConversionReplies: 2Last Post: 8th Jun 2007, 04:42 -
Need help with ffmpeg 2-pass VBR encoding
By SliderVF14 in forum Video ConversionReplies: 8Last Post: 14th May 2007, 18:03
