Is their an easy way to join 2 DVDXCOPY split disc's. I want to join them then use DVD2one to burn them on 1 disc. thanks
rename the .vob files from disk 2 to be in sequential order from the highest numbered .vob from disk 1. Put only and all of the vob files in one folder. Use ifoedit95 to "create ifos". Use the defaut settings. This should create playable ifo files. Then use whatever software you want next.
blind video days at http://home.att.net/~nd4speed
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 23:18 -
AVCHD Disc or Blu-ray Disc?
By p_l in forum Authoring (Blu-ray)Replies: 8Last Post: 19th Jun 2011, 20:56 -
Joining of VOB as 1 with 2 Disc
By pboong in forum EditingReplies: 7Last Post: 13th Jan 2011, 03:57 -
Copping Disc - Disc Data Recovery Software.
By Teac23 in forum DVD RippingReplies: 5Last Post: 1st Oct 2010, 21:06 -
Is it possible to rip a HD DVD disc to Hard Disc ?
By fjmr in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2007, 13:50
