Anyone out there give me some help, I've got an old vhs tape that I want to convert to vcd, I've got an s-video input on my computer, and a tv card.
Just need a few basic pointers thanks
Look at the guides on the left to see if they can help you.
Unfortunately ...... it's not that simple! You're probably going to have to make a stab at it B4 you get much advice ........ but the first basic pointer is to get it captured to your hard drive .... so you'll need a capture driver installed for your capture card, cables for video (video in) and audio (line in & TURNED ON) hooked up from your VCR .... then you'll need to fire up your capture software (like Virtualdub) and grab the VHS tape to your hard drive. After that you'll need to encode it for VSD (like TMPGEnc) , then Author it (like SpruceUp or MyDVD), and finally burn to disk (MyDVD or Nero among many others). There are so many ways to do each step, and much software .... so you're probably going to have to do a little research and practice to get the final results you want ........ good luck.
"No freeman shall be debarred the use of arms." - THOMAS JEFFERSON .. 1776 -
Run your mouse pointer over the "Computer Details" at the top of my answer ...... but, it is a Gainward Geforce 4 PowerPack Ultra/650 XP .... long name but that's Gainward .... they like to use fancy names. Video In, Video Out ..... digital connector (which I've never used) ... and it came with some limited (in my view) InterVideo called "WinCinema". It's not a "TV" card (with a tuner) that I can watch TV on ..... if I want to watch TV ... I use the TV ..... 8)
vhs tape will NOT move through vhs recorder at all
By tepeco in forum RestorationReplies: 52Last Post: 24th Oct 2022, 13:31 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
How can VHS tape color loss be possible? ("tape fade")
By lordsmurf in forum RestorationReplies: 31Last Post: 18th Oct 2010, 10:32 -
vhs ntsc tape
By erlingre in forum LinuxReplies: 2Last Post: 17th Oct 2007, 17:52 -
Archiving VHS Tape
By mts37 in forum Newbie / General discussionsReplies: 3Last Post: 8th Jun 2007, 02:17
