I've encoded a .mpv file from CCE and I didn't do the audio. I now have .mpv and a .vaf file and now I was just wondering how do I get the audio from the original .avi file and add it with a .mpv to get an encoded .mpg file after.
What programs do I need? What steps do I need to go through?
I already have TMPEG.
Thanks!
-Joe :P
You can use tmpgenc, close the wizard and open the avi as audio source, choose audio only and set the correct settings(bitrate and so). If you want a bit better audio quality use toolame with tmpgenc... https://www.videohelp.com/tmpgenc#toolame
After you encoded you have a mp2/mpa file that you multiplex with the video www.dvdrhelp.com/faq#multiplex -
It said "illegal MPEG audio stream" after I hit run in TMPEG. The .mp2 won't even play in Windows Media Player Either.
Do I need to install special software to get it to work with TMPEG or Windows Media Player?
Thanks!
Add audio won't work in audio menu.
By petwes in forum AudioReplies: 0Last Post: 21st Jan 2012, 08:59 -
How does one process mpa and mpv files?
By mysts in forum Authoring (DVD)Replies: 2Last Post: 11th May 2011, 14:30 -
can't play .mpv files with sound
By gbabione in forum Video ConversionReplies: 10Last Post: 23rd Nov 2008, 12:10 -
CCE mpv files imported into NeroVision are half as long???
By binister in forum Authoring (DVD)Replies: 7Last Post: 26th Feb 2008, 16:04 -
Encoded audio is not good - Add better audio?
By NotSoEasy in forum Video ConversionReplies: 2Last Post: 7th Feb 2008, 20:05
