I have quite a lot of Text and Pitcure files I wanted to put on a blank DVD Disk so it can be read in a DVD ROM Drive, I was wondering what was the best programme to use for this and is there anything I should no, is it different to say backing up a DVD movie which I have no problem with. On my first attempt the DVD Rom drive does'nt even detect the disc. is there a guide on how to do this, I have trawled all over the forum and could'nt find anything. Help please?
Regards Patsym1
your dvd rom may not be able to read -r , +r discs
you will prob have best luck with -r ,i have a lg and she wont read + r discs burnt as data disc but will play dvd video even if burnt on dvd+ r
cant figure it out my self
try using a different burning progran -make sure the disc is finalised - -
I have tried every burning programme known to man still no joy. Surely we are not the only ones experianceing this problem.
Regards Patsym1 -
Do a search for Gear DVD
Trial download
For me it will burn data and video to a dvd-r disc with no problem.
Plus it's fast.
GG -
I've burned some data disks with RecordMax Now and Nero, both work perfect.
Greetz,
pSyChO dAdThe difference between genius and insanity is only measured by success ! -
Make data DVD with Nero.
ISO9660 - Mode 1 - Level 1 - Joliet
Maybe even relax restrictions if needed.
Work fine in every DVD-ROM I ever tried.
99.99% of DVD-ROMs can read DVD-R/DVD+R just fine.I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
Bluray player calling blueray disk "data disk" and saying no video files
By jbitakis in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Nov 2011, 21:06 -
Pulling data from disk (DVD+R)
By Antares in forum DVD RippingReplies: 7Last Post: 10th Apr 2011, 08:28 -
WIERD DVD data disk problem
By bruinflight in forum Newbie / General discussionsReplies: 24Last Post: 24th Sep 2009, 23:53 -
Combining data files with a DVD movie on the same disk
By j_p in forum Authoring (DVD)Replies: 6Last Post: 26th Jun 2008, 01:52 -
DVD software to make simple divx data disk
By gthorley in forum Authoring (DVD)Replies: 2Last Post: 8th May 2008, 13:28
