ok here goes, got a divx file which using the guides on this site i extracted the audio using veedub to make a wav file. then using tmpge or whatever it is made a mpeg file. used both nero and vcdeasy to burn this file to cd-r so as to play it on my aiwa xd-dv170 standalone player.
the burnt disks even when burnt at 1x speed still have playback problems on the pc like pixellation and large colour blocks appearing and won't even play at all on the aiwa.
checked the compatability list and it says the aiwa should be able to play cd-r's.
anyone have any experience of this particular aiwa model and using vcd's on it?
and also any advice on burning the discs to get better results, is it just a case of using a particular brand of disc? the ones i'm using are maxell 80min 700 mb
the mpeg files play fine straight off the hard drive.
my cdrw drive is a phillips 48x
any help/advice welcome
ok here goes, got a divx fileTo Be, Or, Not To Be, That, Is The Gazorgan Plan
Advice needed for converting MJPEG from Canon camera
By cdowdy in forum Video ConversionReplies: 5Last Post: 4th Jun 2016, 12:26 -
Help/Advice Converting .AVI Divx Files To ...
By MourningStar in forum Video ConversionReplies: 2Last Post: 12th Dec 2009, 16:18 -
newbie looking to learn seeking converting and burning advice
By jim11757 in forum Newbie / General discussionsReplies: 16Last Post: 27th Feb 2009, 02:16 -
Capture and burning advice needed
By ccm in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 12:25 -
I want to change my burning program, advice needed
By jesterhud in forum Authoring (DVD)Replies: 4Last Post: 20th Aug 2007, 13:43
