  1. I need some advice on making a video montage. I'd like to make something similar to the example on this page: http://www.emrepictures.com/montage/# Essentially, I'd like to have pictures on the screen for about 10 seconds, and then have a transition from image to image (fade into each other). But when the picture is on the screen, I don't want it holding still. Rather, I want the image to slowing be crawling across the screen, or maybe slowly zooming into one part of the picture. I don't want steady images on the screen, I want it moving slowly across. I did some investigating and found out he's using Apple Final Cut Pro, but unfortunately I don't have a Mac. Also, I tried Pinnacle Studio 8 and it was great for the transitions, but I couldn't get the photos to move while they're on the screen.
    Any advice on other programs to try? Or does anyone know how to make Pinnacle Studio 8 move photos they're showing on the screen. I don't care if I have to save the whole thing as an MPG, just so long as they're moving/zooming.
  2. Member djmattyb's Avatar
    Dec 2001
    Seattle
    I've been able to make slideshows like the ones you are talking about. I use Adobe Premiere. You have total control over the images and once you learn how, it is be easy to make a slide show exactly like the example you linked to. Give Premiere a try.
    dj matty b
  3. Can anyone recommend some sort of tutorial for doing slide-show presentations on Premier like I described above?
  4. MAGIX pictures to CD & DVD
    Burn & re-experience your photos on TV or PC
    http://usa.magix.com/index.php?id=411
    Holiday memories - Party snapshots - Hobby pictures - Internet pictures - Family photos etc.
    Are you running out of space for all of your pictures? Store away those clunky photo albums and burn your pictures on CD-ROM or DVD! The hundreds of photos from holidays, landscapes, family & friends and the Internet accumulating each year can now be enjoyed on your TV or PC as a sensational slide show.
    CD-ROM - Video CD - Super Video CD - DVD
    The days of manual slide shows are over. No more tiring set-up of projector and screen! No more searching and sorting through slides! Enjoy the luxury of an interactive photo album and add motion to pictures.
