Hello,
I've hit a problem, almost embarrassing, where I can't seem to record from the PC back to a VCR...
On PC, using ATi All in Wonder 9000 card, it's Composite Out into SCART socket connected to VCR, Scart switch set to 'IN', TV is connected to VCR. Audio records OK but no picture ( black screen ). VCR is set to 'AV' input ( scart is connected to AV1 input )
note: VCR to PC capture using same cable works OK
The Composite Out of the AIW card seems to be OK, as a test you can send the PC display all the way to the TV, using their TV display option.
Using either Ati file player or VDUB to play the AVI on PC
Any suggestions on locality of problem ? ( VCR ? ATi's card doesn't output Video ? )
Thanks kindly,
No luck yet...
Tried another VCR, this time with a Composite in as well as Scart. but still just seeing a black screen when playing AVI's via Ati file player or VDUB.
Can someone possibly confirm that they can record/see video generated on the pc and sent thru to Composite out ( yellow plug ) of the Ati All in Wonder range ( 9000 is the one I have ) to a VCR ?
Odd thing is I can see output when Ati's TV display is used ( ie the TV shows the PC screen )
thanks very much, -
I believe the setting you are missing is "Theater Mode". I'm not in front of my PC but it's in the advanced video settings. Theater mode will show video played from the PC in full screen on the TV. This works with media player/ati's player and it the latest version of MMC it also works with ATI's TV app.
audio gets out of sync when I record to VCR
By lipwak in forum MacReplies: 5Last Post: 26th Feb 2011, 17:39 -
how do i record VCR to PC help
By shockwave972 in forum Capturing and VCRReplies: 1Last Post: 10th Apr 2010, 04:57 -
Record from PC to VCR
By totomomo in forum Video Streaming DownloadingReplies: 4Last Post: 7th Mar 2010, 02:25 -
record comcast hd box and VCR/DVD
By ranger_cole in forum DVD & Blu-ray RecordersReplies: 8Last Post: 17th Jan 2009, 21:50 -
useing a tivo type unit to record from a vcr
By 2boot in forum RestorationReplies: 0Last Post: 20th Feb 2008, 18:36
