I have it enabled. And i guess it speeds up your drive. But thats all I know.
What is it?
DMA (Direct Memory Access) doesn't speed up your drive, it just does speed up your CPU - or more precise, doesn't slow down your CPU! With DMA, the SW gains direct access to the PCI Bus and such can write/read data from/to memory directly to/from the drive without involving the CPU.So, the CPU usage is decreased.
Effectly the HDD speed seems to be increased.
Can you enable DMA for an external DVD burner?
By Erasmus in forum DVD & Blu-ray WritersReplies: 9Last Post: 6th Sep 2009, 10:10 -
DMA changes to PIO for all 3 Dvd drives, even after unistalling IDE driver
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 2nd Mar 2009, 14:45 -
Weird Doings in PIO - DMA-ville
By Seeker47 in forum ComputerReplies: 13Last Post: 28th Nov 2008, 13:15 -
DMA PIO Reg Prob Key Deleted returns after reboot
By tonib95 in forum ComputerReplies: 14Last Post: 4th Feb 2008, 10:23 -
What might make Windows switch a DVD drive to non-DMA mode?
By EddyH in forum ComputerReplies: 8Last Post: 1st Jul 2007, 22:35
