if i do a test capture then burn say five minutes to a cd-rw. is this possible and will i be able to view on a vcr or dvd player to check out quality on tv.
To DVD player, yes, if you comress it to MPEG1 or 2, and the player
can play MPEGs from a directory, or you master the disc as a VCD/SVCD. -
could you please explain about mpeg layer in more detail or point me in the right direction for a tutorial.
I have a jvc xv-523gd player, the manual says it will play dvd, vcd, svcd, cd-r,cd-rw, but not dvd-rom,dvd-r etc.
Is there a small test video one can use to test Rec 601 / 709 conversion?
By Asterra in forum Video ConversionReplies: 5Last Post: 19th Jun 2011, 09:28 -
[b][url]TEST! TEST TEST! WHAT"S THE BEST?!!!!!!!111111
By lordsmurf in forum TestReplies: 0Last Post: 2nd Aug 2010, 03:30 -
Need to make test tool to test Dolby
By djai in forum AudioReplies: 0Last Post: 9th Jun 2010, 07:01 -
Test,test amd propus 630
By budz in forum TestReplies: 20Last Post: 1st Jun 2010, 01:46 -
PSP Test Clip: Need someone with a PSP to test for me!
By FulciLives in forum Portable VideoReplies: 5Last Post: 17th Feb 2009, 21:42
