The newest version of DVD2ONE has a full-disk mode and now allows you to select which audio stream to use. However it does not correct the ifo file so unless you select stream one you get no audio.
Now I discovered while converting a Sopranos episode disk that scrambles the menu playback. While the animated menu is playing static menus keep popping up out of sequence during the animated menu.
While I'll keep using it for movie only backups it seems totally useless in full-disk mode.
Try using Instant Copy and see if that works out better
Thats true, I havent tried it yet. Downloaded it already but havent used it. I'll give it a try tomorrow.
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 03:48 -
DVD2One: Unable to create vobfileset 0...
By Ryan Kelly in forum MacReplies: 3Last Post: 27th Nov 2009, 11:00 -
Weird DVD2one conversion-7 GB compressed to 2.6 GB on diskcopy, why??
By ruggerjvd in forum MacReplies: 2Last Post: 2nd Jan 2008, 11:26 -
Question about seamless joining in DVD2One
By jwnulife in forum MacReplies: 12Last Post: 20th Dec 2007, 07:03 -
Program like DVD2ONE?
By Soccerman77 in forum Newbie / General discussionsReplies: 7Last Post: 26th Nov 2007, 17:11
