My standalone will only play dvd-r's that I made using Ulead Moviefactory2, but the audio is out of sync (no, it was in sync in the divx I made it from). I tried using TMPGEnc, which resulted in an mpeg2 file that my standalone will not play ( I am assuming I need the movie to be in the .vob file format enclosed in a VIDEO_TS file.)
I have not found a patch for the MovieFactory2 to fix the sync problems (which was suggested on this forum). Is the a patch?
If not, can I convert an mpeg2 to the .vob-format? If so, how?
Also, does anyone know of a good tutorial for using CCE? The one on Doom9.org confused me.
Thanks in advance!!!
I use Ulead DVD Movie Factory 2 to convert mpg2 files to VOb, great app.
But there are many others like Sonic DVD-It, Sonic MyDVD, etc.
I prefer Movie factory as you can easily add chapters to a large movie.
Help me, I'm a newbie
By Shadowmistress in forum Off topicReplies: 2Last Post: 19th Jun 2011, 08:54 -
Hello from Newbie
By markwaugh in forum Newbie / General discussionsReplies: 4Last Post: 11th Apr 2011, 13:13 -
Newbie to ripping
By doc-bc in forum DVD RippingReplies: 1Last Post: 28th Nov 2010, 16:31 -
Newbie needs help!!!!!! DVD to xbox 360 streaming
By JohnS719 in forum Newbie / General discussionsReplies: 0Last Post: 22nd May 2010, 08:38 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 09:43
