  1. Hi,
    I have Adaptec Easy CD Creater 4, the basic version that came with my cdr drive not the Deluxe edition. I don't see an option to create VCD's but was wondering if anyone has created VCD's with this program and if so how?
    I don't want to get the $100 upgrade just to make VCD's... Anyone suggest a less expensive burn software that will make VCD's (not trial versions).
    Thanks!
    Apr 2001
    I'd hold off... I've thus far made 1 (one) VCD using Easy CD Creator 4, and this is one that has a "slowdown" effect going on my standalone...
    I don't know if the cause is the encoding (which was supposed to be "standard&quot, or the CD burning program. Since all my other "non-standard" VCD's work that were burned in NERO, I can only guess it's this...
    Try NERO instead if you mean to burn audio/video.
