Hi everyone!
I use DVD Decrypter to rip DVD movies and DVD2ONE to make it fit on a a DVD-5 disc. But when DVD2One is finished it creates about 5 vob files, 2 ifo and 2 bup files. My question is how do i burn it using Nero (i have Nero 5.5.10.20)
can anyone help me? / Rillern
create two folders, one named VIDEO_TS and one named AUDIO_TS (must be in all caps).
Drag all the files that DVD2One created into the VIDEO_TS folder. Leave the audio folder empty.
Open Nero, select UDF as the type of disc to create, and drag those two folders over to the compilation. Make sure that under the UDF tab, you select UDF 1.02.
Burn.
You should be good to go.
The reason for doing it this way is that some versions of Nero, when you make a DVD-Video disc, would burn in UDF 1.05, which can cause compatibility problems. The discs I've tried to burn as DVD-Video with Nero have not worked - the discs I've burned as UDF 1.02 discs work flawlessly.
- housepig -
I use Nero Express and select DVD Video(of coarse) and then click add file and select all 5 files at one time. Then burn your DVD.
SLICK-RICK... I Agree!
Nero Express 5.5.10.20 creates the folders and placed the files properly without a hitch. Just open Neor Express, Select DVD files, and drag in your files! Click "BURN" and you have a compliant DVDOnly 3 things are certain in life... Death, Taxes, and SPAM. Of these, only Death seems affordable!
SVCDummy -
true, I think the new versions of Nero have fixed the UDF 1.02 / 1.05 glitch...
I'm still using 5.5.10.0 on my machine....
- housepig
*lazy*
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 12:42 -
Trying to burn an mkv with subtitles, but the subtitles don't burn properly
By geramul in forum Newbie / General discussionsReplies: 15Last Post: 1st Sep 2010, 19:12 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 04:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 16:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 20:46
