Hi,
I am trying to convert a PAL DVD to NTSC. I have converted each PAL .VOB to AVI and then converted to NTSC mpeg.
The question now, is how do I convert these back to .VOB?
Any help would be most appreciated.
Cheers,
-v20
"Did you see what GOD just did to us??" - Fear and Loathing in Las Vegas
You'll have to re-author them with a dvd authoring tool. Look under the "Author" section at the left.
Drat. What I was aiming for was to see if it was possible to take the existing .VOB's in PAL format and just convert them to NTSC and replace them so the disc would still run the same.
I know I can reauthor them, but some dvd's it is virtually impossible to recreate the original menus.
Or at least, I dont know of any way - the menu item selection options in the authoring tools I have seen are pretty limited.
Back to the drawing board...
-v20"Did you see what GOD just did to us??" - Fear and Loathing in Las Vegas -
You can do this with IFOUpdate:
http://www.doom9.org/mpg/maestro2.htm
Basically, you re-author the the VOB of interest, delete the old VOBs, use IFOUpdate to fix the IFO files, then re-burn.
How to mux M2V and MP2 ?
By aussie74 in forum Authoring (DVD)Replies: 5Last Post: 19th Mar 2012, 08:17 -
Extract .m2v and .mp2 files
By geohei in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2010, 13:42 -
Freeware to mux mpeg-2 (m2v mp2) (NOT TMPGEnc)
By 2397to2997 in forum Video ConversionReplies: 12Last Post: 18th Aug 2010, 16:42 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 21:25 -
free m2v+mp2 multiplex (other than ImagoMPEG)?
By tff in forum Video ConversionReplies: 3Last Post: 4th Jun 2009, 10:31
