How do you convert a wav file from Tempg to mpa for IFOedit?
how do you mean a wav file from Tmpgenc???
If wav comes from the source (avi) you can use tmpenc to convert the wav into mpa/mp2.
1. Close the Project Wizard
2. From the main window at the bottom right it select audio
3. Select the audio only file no need to select vid.....
4. Give it whatever name you want in out put
5. Hit Setting and here you can choose your setting like 441khz or joint stero etc
6. Hit Start....
Easy way to convert wav to mpa/mp2. It works everytime for me. You can use other apps like headache or be sweet but be sweet annoys me and sometims (for me) headache doesn't work ,...........might be something I am doing wrongHow long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
If you like Tekno download one of my tracks
www.users.bigpond.net.au/thefox149
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 13:36 -
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 16:14 -
delaycut - ac3/eac3/dts/mpa/wav delay+cut tool: v1.4.3.2
By amtm in forum AudioReplies: 21Last Post: 23rd Nov 2011, 08:34 -
How to convert WAV/MPA/MP3 to AC3 6 channels?
By katalogas in forum AudioReplies: 8Last Post: 16th Feb 2010, 14:12
