When converting a long video stream to mpeg1... the resulting mpeg1 stream has a still video frame for a length
of 1 minute every 4min44secs. For example, you've converted a 15minute stream into mpg1, when you play it back you will see a 1 minute sequence with a freeze frame running for about 1 minute starting at 4mins44sec, then a normal stream until the next 4min44sec interval and so on. The audio is fine though. I normally encode OpenDML Avi's but I've tried it with Quicktime other codes with the same results. What could i be doing wrong? Thank you very much for your help.
Results 1 to 1 of 1
need some help with sequence maker
By beta72 in forum EditingReplies: 1Last Post: 17th Oct 2011, 21:44 -
best possible sequence settings
By pjcom in forum EditingReplies: 15Last Post: 26th May 2010, 11:12 -
Recomended sequence.
By Tafflad in forum RestorationReplies: 0Last Post: 19th May 2010, 16:31 -
BMP to AVI sequence
By max_e_mum in forum EditingReplies: 6Last Post: 17th Aug 2009, 06:57 -
VIDEO TS sequence
By red lion in forum EditingReplies: 1Last Post: 25th Jun 2007, 20:15
