  1. I've successfully converted and burned a number of DVD movies form divx and xvid. I've been trying to convert an xvid film to dvd in tmpgenc. My first problem is that after I stip the wav out in virtual dub and then run the avi and wav through tmpgenc to end up with an mp2 and wav file i have lost all the sound. Even when i try to play the wav file on it's own n media player it's empty. The wav file that virtual dub output is fine however. Any ideas?
    Secondly using the final stage of the tmpgenc wizard I try to set dvd films to take up 85% of the disc and let the application choose the most suitable bit rate. When i then try to author the dvd in MovieFactory 2 the file size is way over the permissible 4.7Gb. Is there a more reliable way to fill a disc? Perhaps there's a better application than moviefactory. At the moment I just set tmpgenc to fill half the disc and it seems to work.
    Any help much appreciated.
  2. hi i use ulead dvd moviefactory 2 and burn the movie to hard drive first. I dont use Tmpg i used it once but it sends the movie out of sync i just run the avi though DMF2 it takes a bit of time but it keeps everything in sync then if it is over 4300 i use DVD 2 ONE to bring it down then burn with nero 12 movies so far touch wood no problems. hoe that is of help
  3. Gary,
    good idea on the dvd2one method, I'd not thought of doing that. When ever I've tried to import avi files (xvid or vidx) into moviefactory it errors with a messgae like "file type not supported".
    My understanding is that tmpgenc is the only tool that imports divx and xvid movies prior to conversion to a dvd. Am i wrong here?
    My usual method in moviefactory is to input the m2v file that tmpgenc outputs and then i 'replace the audio' with the wav file that tmpgenc outputs. i've not had any problems to date, not quite sure what's going on.
    Again, any help much appreciated on this sound issue.
  4. try running them through VDUB and save the output files as avi files then run DMF2 as i have all ready said not realy been using Xvid vidX that might help i allways run VDUB
    open file in VDUB
    audio settings AVI AUDIO
    VIDEO settings direct stream copy
    save as avi
  5. have you got upto date Xvid and VidX codecs that my well be the problem you are having trying to load your files into DMF2 i have just downloaded XVid screaner and DMF2 has loaded it without any problem
