I've captured a couple of clips (one 8gb, the other 1gb) and Windows XP won't let me delete them.
It says there are in use by another program.
I captured them all using Vdub and that says the file is in use or in the editor (???????).
Everytime I capture a file I can't delete it, and I've checked the task manager and closed everything I can but I still can't delete them.
What have I done and more importantly what can I do?
Thanks,
Will
Results 1 to 22 of 22
tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
You need to edit the registry - it's default handler is messed up for avi's in XP (some versions)
Registry Edit for WinXP Prof. If unable to delete .avi’s from Explorer
Delete the lowest folder …. leave the upper structure and just delete...\InProcServer32
Start regedit and remove the following key: HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{87D62D9 4-71B3-4b9a-9489-5FE6850DC73E}\InProcServer32~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
Another way that works about 80% of the time if your not comfortable messing w/ your registry is try and play the avi file and right after you exit playing the file hit the delete key.
Thought I'd offer the alternative for those who dont want to hack the registry. -
Originally Posted by Treebeardtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
Originally Posted by spidey
Anyone know how to remove all traces of Virtualbub from the registry?
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Maybe this will work? worth a try.
Is the file in a folder by itself?
If you could isolate the avi in the folder by itself then just try and delete the whole folder. -
I'm sure it's a virtualdsub thing, if I capture using the ATI remote or FreeVCR then delete those they go away fine.
Thanks man, worked great
Appreciate your help, I was beginning to think I'd have to format
I didn't realise the {87D62D94-71B3-4b9a-9489-5FE6850DC73E} in your message was the same in every computer - let's just say I deleted a different one before I found the one you were talking about(let's see if the computer works tonight!)
Thanks again,
I didn't realise there was a registry hack - the only way I've found around this is to boot, hit F8, select "Safe Mode with Command Prompt", navigate into the folder that contains the .avi and delete it from there.
Wc -
Without hacking the registry, I've found that renaming the whatever.avi to whatever.txt, THEN deleting it, works....
Originally Posted by Robert Simandl
but thanks for the suggestion
That's how I knew I had a problem, I was trying to rename the file but it wouldn't let me (then it wouldn't let me delete it).
Rebooting into safe mode would certainly work but take hours (for each file imagine!)
Sometimes, If you don't wanna hack the regisrty, going to a command prompt and hitting del (FILE LOCATION and NAME) will work.
However, If the file thinks Its still being used in the capture program, sometime even the command prompt doesn't work -
Originally Posted by dcsos
..the command prompt gave me the same message, 'file in use'
Thanks,
this might be a silly suggestion, but have you tried restarting your p.c and then trying to delete the file?
normally works for me... -
Glad it worked............
Come on guys - the simplest and best way is to edit the BS M$ avi handler. Greyhair had referred this to me, and I do believe it is also located in the Guides section somewhere.
Why in the hell would you want to rename the file, reboot your pc, stand on your head for 20 seconds, turn around 3x, sing a song, wait for it to come back up, then you can delete the file.
LOL~~~Spidey~~~
Originally Posted by kas187
I tried that four times
Thanks anyway,
Silky31,
No, you're right Bud. I was not poking fun at you.
I was just poking fun at some of the other work arounds, rather than them simply deleting the M$oft key which is causing the handler in the avi processing.
It just seems absurd to shut down, or have to go into safe mode each time you want to delete a file.
But to each his own and I mean no offense to anyone, just trying to help out.~~~Spidey~~~
Hey!
I was having a friendly dig at kas187 pal, not you spidey!
You have no idea how grateful I am to you that your suggestion worked, I was getting real worked up about it too, I'd never had it happen to me in eight years of using Windows and it was late at night and I didn't want to sleep without solving it (I'm odd like that!!).
I was just glad someone knew the answer straight away.
I'd edited 45 mins of anologue footage, it had taken me three hours and then I started with these error's.
To top it all I accidently deleted my 8gb capture file (after I edited the registry) and lost the file I'd spent three hours editing.
Back to it tonight, and that was only the first 45 min tape, another nine to go
Thanks again,
This happens in W2K sometimes as well. What M$ is doing is 'preview' the file, hence it's 'in use'. You can delete them from a command prompt. You can also delete the folder they are in. As a side note, Daemon Tools (bin/cue mounting as a virtual drive) does the same thing with the folder of the file you last mounted (even if you unmount all drives). You mount, verify everything is in sync, burn, but can't delete the folder you put them in....oh well, jsut mount something else.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Originally Posted by Gazorgan
I acknowledge I have limited knowledge of dos, I simply navigated to the correct drive (V:/) and simply typed:
DEL FILENAME(.avi)
Having tried that all I got from the command prompt was words to the effect of 'file in use etc.'.
Saying that, I'm not entirely sure why deleting from the command prompt would be a benefit. Sure I can get rid of the file but each time I captured I couldn't delete that either.
Best way is to edit the registry for sure.
I found out that if you open another video file after viewing your cap. then it will del just fine. Using command prompt works just fine to (Start - Programs - Accessories - Command Prompt) drive:\ cd\folder del\file name
hope this helpsIf it dosn't work read and read some more. Try it again. It could get old quick but when u finaily get its well worth it.
LG HDD DVD recorder won't delete
By kimmie23 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 19th Feb 2010, 02:27 -
Folder Won't delete
By jollyjohn in forum ComputerReplies: 4Last Post: 8th Jan 2010, 08:10 -
Question how to delete files that won't delete
By jimdagys in forum ComputerReplies: 18Last Post: 9th Sep 2009, 13:09 -
PowerDVD XP 4.0 Won't Play in Updated WinXP
By SLK001 in forum Software PlayingReplies: 4Last Post: 14th Aug 2007, 11:05 -
computer freezes, won't allow WinXP install
By iThinkYouBrokeIt in forum ComputerReplies: 15Last Post: 13th Aug 2007, 18:07
