  1. Hi,
    I'm just a newbie in burning sphere and I just discovered this forum. Amazing !
    But I have not the answer to my proble : is it possible to make easily a photo album with an index ? ie an index for france, another one for usa, another one for britain etc..
    Is it so much complicated ?*
    TIA
  2. The easiest way would be to use videopack. VCD2TK is a little bit more difficult to use but its free!
    Download the VCD2TK "learning by doing" example below:
    http://www.icdia.org/cdprosupport/files/pc/shortst.zip
    Remember that it is important to follow the whitebook specification, i.e. you need to have an mpegav file on your vcd. (My philips 711 showed "disc error" when I don't include an mpegav).
    To make the mpegav file compliant with the whitebook follow the guide:
    "How to use TMPGEnc to create assets", which can be found at:
    http://www.vcdhelp.com/VCD2TK_Index.htm
    Good luck!
